01 SAS Wheeler/Driver 3link
I was pleasantly surprised by how easy it was to rebuild the door hinges. That interior is rough for 140k
Ya. I like how everything isn't loose so you have to line stuff up. Just set it on and its all lined up. It does look really bad in the pics when I fixed hinges. The worst is the driver seat, thats about it.
Got a 60 From Andrew at Letz roll offroad in AZ thanks to Shawn. And a big thanks to Jason at Pacific fab to bring it up the state after KOH.
79 Hp60
4.88's Yukon ZIP locker
35 chromo stubs and Hubs
Needs a good cleaning and some brackets to come off, then paint
Haha, you're right. Also I was slightly drunk when I posted that....
Martin
So, I have been working on gathering all the little interior pieces that need fixing and getting seats all shampooed up. Just a lot cleaner now to drive around while I tear down the 60 and get new seals and bearings in it.
79 Hp60
Just finally cought this, after all the Convo it's awesome to see the truck and plan coming together.
Sweet!
:thumb::thumb:
-shawn
Did a little researching on the radius and that's a no go. So, 3 or 4 links the plan and I'd like to tackle the build myself but with help. I plan on using the Artec truss to match the rear I have. I don't think I'll have a problem building brackets but I have a few questions.
How do I determine the lengths of links?
Where can or does the top link need to be?
I think I have space to do even a 4link. Better?
I really like the idea of the 08 Z71 ultimate adventure, where they bent the bottom links just a bit for tire clearance. More so that the brackets came straight down from the frame for strength. I can put the upper anywhere it will fit best either on inner frame or build a new xmember to put it on.
http://www.fourwheeler.com/project-v...photo-gallery/
I have a buddy planning on doing a sas on a similar truck (except 1/2 ton). What makes the radius arms a no go?
Radius arms are kind of goofy.
It puts a lot of stress on the arms from wanting to twist apart when binding. Because of this it will be murder on joints. Although you can mask that by making a longer link but that sacrifices ground clearance. Yes many manufactures have done this and it works but for the wheeling he does I would stay away from it.
