Maybe it needs a 465?
Iffy ground?Truck has been running fine. Hit the 161k mark.
I have had an issue since I installed the cruise control switch. This was in Colorado. When the temp is below 40* outside, the cruise will not turn on. At 40* it will work until the wipers run. If they are on intermittent, you can set it between cycles then it shuts off. Above 50*, they work fine.
What the heck?
You should probably scrap it
Iffy ground?
Ah gotcha.The wores we re pre wired by gm. Just pulled the dash surround and the plug was sitting right there. Pulled the steering wheel and old switch. Plugged new one in and it worked. Mostly.
My Yukon had similar issues, turns out the turn signal stalk wears out, and the ground for it can have issues too.The wires were pre wired by gm. Just pulled the dash surround and the plug was sitting right there. Pulled the steering wheel and old switch. Plugged new one in and it worked. Mostly.
