03 1500, Sold it.
ktmoutfront
We live in the stupidest times.
In my shop. Doing stuff.
ktmoutfront submitted a new Build:
03 1500 flat bed build
Bought this truck, 4wd, 5.3 base with 105k on the odometer.
Truck was beat on by the previous owner. Tried to be a snow plower. Back into a Mercedes on his first day. Must have been moving.
I was going to pull the body and set the blazer on it. Lowered 4wd DD. FTW.
Not going to happen. So I am going to build a flat bed.
Already added electric seats and cruise control
Today it started.
View attachment 218314 View attachment 218315
Hitch is a little bent.View attachment 218316
Bed removal by myself.
I new I had to deal with this.
Got it straightened out with big steel, clamps, BFH and a lot of heat. It is straight and square. Measured diagonals and it is 1/16" off. Only issue is, and it is a big one, the frame is twisted. Right rear corner is 1" higher. Blocked the left side up and tried to push the right corner down with the skidder. No dice.
Will try something else tomorrow.
I guess I should describe the future bed. Aluminium frame and sides, shortened to 7 feet long so it will fit in the garage. Recessed rollers in the surface. Sides will be removed and used to widen bed if needed. The back section will extend to 10 feet long if needed.
I have 9 days to have it usable.
Read more about this build here...
Driving to Phoenix to pick up my boy. Then off to mom's in Lake Havasu for a couple of days. Then head home with my boat that has been sitting since 1995.
I needed another project.
Oh i didnt know you were chasing the boat with the project. Cool
It's not little. Weighs in at 8550 pounds. Has a bad hydraulic leak I have to fix for the owner. He stores it at our church, so I can use it whenever.
Sounds like a neat project, if you need any help while your in Phoenix let me know I'm not far away.
Did you figure out the seat issue?
