06 Savana w/6.0l, bad valve seals an easy fix?
cabledawg
Secret Squirrel
Highway to Hell
So we've had this Savana van for 2.5 years, put 40k miles on it (its almost right at 140k on the odo), and now whenever its sat for a few hours, it smoke on startup. Not much, just about 10-20 seconds or so. It'll taper off than its good the entire time the engine is running. So I'm pretty sure its the valve seals.
So here's my big question: how hard is it to fix valve seals on an engine that is 70% buried under the body? It has the doghouse panel, but I'm not 100% sure I can still reach the entire engine, I thinks its more of a courtesy panel. In the short term its not going to hurt anything (just gotta watch the oil levels a bit closer), but what about the long term effects? Can I just leave this alone till the rest of the engine craps out or should I look at scheduling a head job (hehe) in the spring?
Tahnks in advance guys!
Long term effects I can think of: fouled spark plugs, (obvious) loss of motor oil that you'll have to check periodically, and in a couple really extreme cases, I've seen soot buildup that kept the exhaust valve from seating completely - this can cause a lot of problems, but you'll know it.
I don't know the savanna layout, but a lot of those types are easier to just pull the engine cradle out of the bottom to work on. Sounds extreme, but it's not usually as complicated as it seems.
I don't have experience first hand with one but I have been amazed at how much easier it is to access the motor with that doghouse off than working on a regular truck in some instances.
Valve seals you'll need the compressed air adapter to pressurize the cylinder and the correct spring puller for the engine with the head n the vehicle.
I'll have to pull the doghouse and see how much room I have. I was very surprised when I did the water pump last year and didn't need to pull anything more than the shroud and fan. So we'll see. Since I don't have a garage this fits into, I may just wait till spring......
With a 140k on it, no way I would worry about it! I had one that smoked a little on start up for 250k miles. I sold it and the other owner put another 25k on it.
