10 BOLT carriers ?
yes it will friend has his gov bomb in his front after he got gears now it has 14 bolt and detroit and gov bomb up front
K10ANDYKHAMNIC said:
Will front and rear 10 bolt carriers interchange ? :confused: that is all .
Yes. However, you must match the spline count. Some are 28 spline while others are 30 spline. Unless you also want to swap axle shafts, make sure you have the right carrier for the job. :eek1:
Triaged said:
I don't think a TrueTrac can swap from front to rear...but I'm not sure.
Correct. There are different part numbers for the TrueTrac, depending on whether it is for the front or the rear.
good point i forgot to mention that
readymix said:
just switch the spiders
I've been told that it only works when putting 28 spline spiders into a 30 spline carrier. Supposedly the hole in the 28 spline carrier is too small for a 30 spline axle to fit through. :confused:
That's correct, which is also what makes the 30 spline carriers marginally weaker than the 28 spline counterparts.
I have 30 spline front spares , and a 28 spline carrier on the bench . I should verify this sometime . but time is hard to come by after work !
they will swap front to back and vice versa.
ive got a nib 10b carrier 28spline in the for sale section f you need one :-)
its been a while since ive been in a 10 bolt, let along have the carrier out, but it seems that the hole that the axle goes in is huge and the side gears are what fill this hole in. according to everything that i have found, the major diameter of the shaft is the same, just 2 more splines.
