14 bolt outer seal- leaking again...
old trick also red loctight on the seal area before speedi sleave .
and I have just tapped it on slow with the back lip and been fine .
also the big cup the sleave come in the box in works great as a axle nut socket storage cup in your tool box to keep grease / oil in the cup .:D
good advice! Im going to go ahead and do the speedi sleeve. amazon 44$.
X2 for all speed sleeves
It seems to have worked. I'll have to post before and afters.
another plug for SKF 28554 Grease Seals. they do not turn on the seal surface.
another fix is the SKF 28554 Grease Seals. they do not turn on the seal surface.
I considered those as well. Everyone seemed to root for the sleeves so I went with them. That surface was pretty bad though.
