79rustyk10
3/4 ton status
Holy blast from the past.
I thought the AXN 14bsf came in GMT900 trucks and SUVs with the 6.2L? And as far as I understand it's also the only 6 lug 14bsf to come with rear disks? I have the AXN rpo code in my '12 1500 with the 6.2. Did they use the code on earlier trucks too?Re: the hybrid axle I referred to above.
I'm going from memory here, so.....
The RPO code is AXN. This is the GMT 400 series. Basically its a light duty 14 bsf. It uses 10 bolt wheel bearings, seals, and brakes. IMO this one should be avoided.
As for axle lengths you can fan a spacer to move the brake backing plate out 1/2" if required. I'm not sure, maybe swapping backing plates will work.
There's a lot of good info in the link I posted above
I had a pic of the spacer specs, can't find it in my tablet at the moment.
hmmm the steel 8x10 rally style wheels (i assumed were stock gm but who knows) -they have 45,000 miles on them and have been jumped, flat tired, rotated positions, and on/off a million times. I've never noticed a problem. cant remember if the fronts end up being hub centric on the 4x4 hub, but im pretty sure the backs do not on the SF14, and center when the lugs are tightenedMy take on reading that was that the larger lug nuts were more of a pinch fit than seated taper without drilling, and drilling may not allow the smaller lug nut tapers to seat and tighten before bottoming out?
15x8 rallys are definitely not hub centric, front or rear. Nor is any GM wheel of the era.hmmm the steel 8x10 rally style wheels (i assumed were stock gm but who knows) -they have 45,000 miles on them and have been jumped, flat tired, rotated positions, and on/off a million times. I've never noticed a problem. cant remember if the fronts end up being hub centric on the 4x4 hub, but im pretty sure the backs do not on the SF14, and center when the lugs are tightened
okie dokie. i guess more accurately, they center hole fits snuggly on the hub. probably just a coincidence or maybe i haven't taken a tire of of that thing in a while!15x8 rallys are definitely not hub centric, front or rear. Nor is any GM wheel of the era.
this thread was just brought up again - so much good info on the 14SF!!Even the 1/2" studs I swapped to seem to loosen up a bit on the stock rallies, and it sure seems to look like the lug nuts arent getting a real good taper fit on the rim. Only took off one wheel (odd, probably chinesium issue with the brass of the valve stem breaking off with the valve stem cap), but one of the holes had a sliver of steel where I assume the lug nut took some material off. I was changing a tire in the snow so didn't have a ton of time to examine the cause in depth. But checking the other wheels, lugs were definitely loose compared to what I had torqued them to before.
You'd probably see any mismatch in taper by rust forming where the old 7/16" lug nuts used to make contact.
