1968 C10 DD, project "New Tricks"
Those are long beds fellas. I can get a nice long bed for a good price all day long. There are even several short bed frames with flat beds available now. Rather work on one of those. Got some complete short bed trucks I'm looking at too, just needs more work.
Called two more today. One number was disconnected :( and another led me to a crackhead women helping the non-English speaking owner sell. Lol
I can afford $22!!! Hell yeah! :D Long bed and probably out of my price range, plus needing to be shortened :(
but boy that's a nice truck
Well....
I said Eff it. I don't want to pay for people's modifications and most prices are for what people think are awesome garbage.
So... I'm the proud owner of a short bed rolling chassis. Looking for a nice long bed now. They seem to be cheap and plentiful. Also picked up some CPP stuff at 20% off show price. :D
Nope, sorry Jeff. I owe ya some beers for that one. Wasn't real happy with fixing all the rust, plus swapping out the front clip. Considering it had a flat bed, it's really no better than a long bed without the bed. The motor did sound kinda awesome, but it won't be in the truck for long.
Trust me, it was a spur of the moment idea. I found the frame and figured "what the hell". Going to strip it of all the suspension etc. I'm going to set it up the way I want and for the drivetrain I want :D I'm finding cheap long bed trucks with good interiors and clean metal all the time. This will be my donor for a complete cab and '67/'68 front clip. Depending on CList bed selections and prices, it will either get a bed later or I'll make a flat bed for it.
LOL I guess I'll start a build thread :D
So far all I have is a nasty looking frame. It will get stripped down and sand blasted. I will more than likely prime it and paint it with some Black Rustolium oil base stuff from Home Depot. I don't want to powder coat it. It will cost a lot more and can't be touched up.
I went off the deep end at a car show today. I didn't find any good trucks but I did find the CPP booth :doah: They gave me a little over 10% off everything I ordered plus no tax :woot: Needless to say, I don't need much more for the chassis. It will be a 3/5 drop. The 4/6 drop is nice looking, but not practical for my areas or a daily driver. Also, some of the parts are specific to LS/4L60 swaps :D
You owe me nothing! I'm glad I could help. Sounds like you have lot of fun work to do. Sounds like it will be a sweet truck!!!
Well, you could let me do a few donuts in it when it's finished!!! Kidding.
of a nasty frame and parts I haven't gotten from CPP? :haha:
Yep, that's as far as the build has gotten. :doah::haha: In fact, I don't even have the frame yet. It's still at the ex-owners house. Trying to get back over with a trailer to pick it up. :woot:
Ok, first question as things come together.
What's the difference between a 4L60 and 4L80? Just strength?
This truck is a pavement pounder that might see a boat or utility trailer from time to time. So if I come across a 5.3/4l60 combo in good shape with throttle cable operation, I'll pounce on it. Same goes for a 6.0. I'm not really leaning towards one over the other, it's just a nice daily driver. However..... if I come across a 6.0/4l80 in good shape......:D
Wondering if the larger trans is going to give me floor clearance issues or not. LOL and on this project, a body lift is out of the question. :doah:
I really need to start researching some other similar builds. I'm trying to make this all happen as quick as possible. I only have parking for two cars and the city charges $150/year to park on the street. (if they feel you don't need a spot, they can reject you) Also, they are not going to like seeing this build out in the open, they always give me grief. Once the C10 is reliable, my S10 will be for sale.
My biggest worries right now are:
-Proper tank under the bed with proper "in tank fuel pump" set up (can I run a blazer tank like the '91 in my K5 now?)
-Shifter linkage. Also trying to find which older Chevy van people are pulling the tilt steering columns from. I guess they are a direct replacement for the older C10s. Aftermarket companies want $$$$$$$$ for columns.
-Wiring. I don't like the job I did on my K5. Since removing all the electric window stuff, I can simplify my wiring once I remove my dash in the K5. For the C10 however, it's all manual windows and will more than likely get an aftermarket HVAC system to clean up the firewall. So I'm trying NOT TO use a regular fuse panel, but something easier to work on and modify. Just don't know what or how. :(
My head is just full of crap right now. The frame, suspension, and driveline will be the first to get done.
red
Strength, parasitic drag (little more on the 4l80e), and the 80 is a slight bit bigger.
Think about stock applications for each. The 5.3/4l60e came stock in a 1500 pcikup with a tw rating around 8000lbs or so. It will get a couple MPG better than the 6.0. In a 1/2 ton cruisier truck, i would just get a 5.3/4l60e. Plenty strong, plenty fast, and a couple more mpg.
I dont think there is a big enough external difference between the two to worry about.
Thats what i would do.
Pretty sure its any van from like the early 80s to the late 90s.
PERSONALLY, I would get a new wiring harness for the 67. And then have your LS harness modified by the modifer of your choice, unless your feeling a little extra frisky, then a new LS harness would be the ticket. The new 67 harness would only have one or two wires to be removed, and the ls harness would only need 3 or 4 wires to be hooked up. Easy money.
