I don't notice fuel smell in the cab of my 66. It will stink up the garage if I park it with a nearly full tank. 1/2 tank and its fine.
Headers I prefer ceramic coating.I think a nice “old school” look would look cool. So, in going forward with these Ram Horns..
Why is one set of bolts longer?
Ceramic coat then or Silver vht paint?
That sounds like a good plan, even logical.I would like to move the tank. But I already have a new behind the seat tank, fuel sender. So in a cost saving manner, for now I’m going to keep the tank behind the seat.
Just fill with fluid and check?Lines look good, pull the drums off and have a look at the shoes and hardware. Check for wheel cylinder leaks, and rusty components. If they look good run em! Be aware they may be grabby though the first few times you use them.
While I’m not entirely opposed to this. Id Rather not just yet. HaBy bolts of different sizes and see which one fits.
I see this but the question was never answered.
What is the length of the bolt that goes through the perch to motor mount?
I assume these are bolt in the pic but I love no luck finding the length. They like 2 inches
When I google “perch mount bolt” I keep getting what looks like clam shell bolt lengths that attach horizontal. I need it to go up through the perch to the motor mount and no way is that bolt 4-5 inches in length
Nope... they came with bolts to mount to the engine and the long bolt for a clam shell or tubular frame perch. Not the 67-72 perchDid the bolts come with the mounts?
Looks like the ones in the pic should be fine. 2” seems right to me?
But I’ve never had a truck with that style mount.
It’s lame. You but the expensive polyurethane motor mounts you get the perch to mount bolt but not the 3 bolts to bolt it to the engine..
You buy the cheap motor mounts you get nothing.
You buy the “bolt kit” and still don’t get what you need
Granted I can be a bit doltish in this stuff but it’s annoying AF spending endless hours looking for bolts.
