What are you using for the clutch master cylinder and line to mate up with the internal slave?
I wonder how hard it would be to adapt to a stock squarebody master cylinder. I'll be swapping in a similar internal slave nv4500 when I do the 8.1 swap on mine.McLeod makes a 4an line with quick connect to for that slave. That then is adapted to my Willwood .700 master
Bingo! Thanks!With stock square hydraulic pedals it should be easy. Determine threads on master and get matching 4an adapter fitting, use this same McLeod line and done
Had a buddy drop off a 32 spline NP208. Turns out it’s cracked. This will be good for mock up and getting the drivelines figured out.
I recall seeing somewhere I could swap inputs on the 208? Say I find a 27spline one, I could swap the 32 spline input shaft? Anyone done this
Nice. Few options. No idea how I’d know how long of cable I need tho
Little extra cable stuffed under the cab won't hurt. I would say put it all in (tcase). Once your all set then measure for a cable and order.Nice. Few options. No idea how I’d know how long of cable I need tho![]()
Jon at JB Fab is very helpful. Also I believe @Kay86K5 had this shifter before he went twin cases.
