With that strange 3 3/4" size you are very limited on aftermarket gauge options. I do like the factory "recessed" look though.
If a guy was motivated enough I'd think you could probably shim it or make a spacer out of HDPE.With that strange 3 3/4" size you are very limited on aftermarket gauge options. I do like the factory "recessed" look though.
I had only seen the digital bar graph style, I didn't know they make the dial type. I kinda like the numerals and the full sweep.There is another company that makes drop in gauge inserts I can get now very recently. Intellitronix I think. They offer different colors of analog gauges.
Found it...
https://www.intellitronix.com/chevy-truck (scroll down you'll see they offer needle and bar graph style)
I don't have any personal experience with them, but they look competitive.
I was afraid I might have trouble with the tach conversion because the one I saw from LMC is listed for 78-87. Wasn't sure why 73-77 wouldn't work. Otherwise, I'm definitely interested.Switching out the ammeter for a voltmeter is pretty simple. I did this on my ‘75. Pull the amp gauge out. I added a couple wires to the back of the volt gauge with ring terminals. One went to ground and the other plugged into an open port on the fuse panel. I popped the clips that hold the gauge to the cluster and make the connection to the printed circuit out. I popped the clips back into the cluster without going through the printed circuit. I think I added tape or something to further insulate the clips from the circuit. Details are a little fuzzy as it’s been close to 20 years since I did that.
But the volt gauge worked like it should and I think it was a little more responsive as it had less resistance to work through.
I have a spare factory tach we could work out a deal on that I’ll probably never use anyway.
I know there are devices that work off the vss to drive a mechanical speedo cable but have zero experience with them.
I agree with you, the bar graph definitely looks like modern 80s , not factory.I had only seen the digital bar graph style, I didn't know they make the dial type. I kinda like the numerals and the full sweep.
I was just thinking if I keep this up, I'll never get the L29 into the crew cab.I agree with you, the bar graph definitely looks like modern 80s , not factory.
My place has 2 of the analog needle type in stock if you decide to go that route. No worries either way.
Back when I was looking for the breather grommet, I replaced the PCV valve with a fancy dual-flow unit https://mewagner.com/?p=444. I was annoyed by the oil mist around the breather, oil fill cap, and PCV. The breather had so much oil coming out, it was putting oil all over the spark plug below it. Every time I did a search about it, this M/E Wagner PCV would come up. I decided to give it a shot, and it works great. My valve covers are clean and there was a little bit of seep at the front of the oil pan and that's stopped too. I've driven it several hundred miles; I hadn't posted about it earlier because I wanted to see how it would work.
You can read the science on the website, I would just be regurgitating it here. The key is the dual-flow design and the fact that it's tunable.
I plan on getting one for the crew cab next.
I decided to use the Dakota Digital speedometer adapter. It was difficult to find a place to mount it due to the size of the box and also having to figure out a good way to route the speedo cable which isn't very flexible. This was the spot that I came up with:
It's connected to the speedo output from the Edelbrock trans controller. The easiest way to calibrate it is with the app thru bluetooth. So far the needle seems to be a little sluggish. I don't know if this is the Dakota unit or if it's my speedo. It wasn't smooth with the cable connected to the TH350. I'm thinking maybe I need to pull the speedo out and clean it up.
I thought some about that but I was concerned about oil fumes. If it's not an issue, I may go that route with the crew cab.Those pvc vavles are supposed to be the ticket.
I'm just way to much of a hillbilly to spend that kinda money on that.
I just oil catch can my stuff and call it a day.
Also update on the quote above about the engine randomly cutting out on me. @folkenheath recommended pulling the ground for the fans off the battery (where the efi is grounded) and putting it on the frame. That seems to have done the trick. It's been warm enough to run AC several times this month and I haven't had any cutting out issues.That thought crosses my mind frequently. Even my wife made that same comment. But when it's good, it's so good. And it hasn't left me stranded, that would be the final straw.
That being said, I'm still having a problem with the PF4 completely cutting out randomly and for short bursts. I thought it was the fuel type, but now it's happened with the ethanol free. I've been slowly narrowing down the circumstances and I think it's gotta be picking up RFI from the PWM fan controller.
It's never acted up on the morning drive. It's cool enough in the mornings the fans never come on, even in the summer. Every time it's happened, the fans have been on. It's frustrating because it doesn't happen every time the fans run. Based on my experience with the glitchiness from the fuel pump not being on a relay, it seems plausible the current glitching could also be from electrical interference.
I'm really torn about it because I really like the controller. The soft start makes it so you can't even tell when they start running. Once they're going, they modulate to a steady state where the fans just run at a steady speed that maintains coolant temps. There's not the constant on and off of the fans cycling as the coolant temps rise and fall.
The hood continues to go away.
I did rub all over the truck today to make it shiney again. Actually it was my first time machine polishing and I like it better.
Because It’s not fuel injected?How do I not know about the truck in front of it?
I had carbureted vehicles for decadesBecause It’s not fuel injected?
