I'm messing with you. I just like the idea of a carb on an old street truck.
I like Amazon because I hate having to go to stores, but sometimes you need something quicker. But then having to visit 2 parts stores to find what I need reminds me of why I order online.
I installed the Square Body Syndicate bowtie on the grill. It looks very nice!
Makes me more motivated to replace it with something else. Gonna keep it bench, but I think I'll look for something from the 90s.What size tires?All is right in the charging world again. New 12SI 100amp alternator and Deka AGM battery. FYI difference between old 10SI and new 12SI.
The 12SI has better cooling and higher rating, straight bolt-in swap; that's why I went that direction. Although the 12SI is metric.
This truck pulls really strong. I was thinking it might have 3.73 rearend but yet it runs a touch under 2200RPM @ 65mph. After some interwebs searching and gear calculator verification, I discovered it has 2.76 gears which was standard for 10blt equipped C10's. Man I'm impressed with the acceleration. I don't know if it's the Street Demon carb or what. That carb has the smaller primaries like a qjet.
I also learned something slightly annoying after further searching. I couldn't for the life of me figure out how to fold the seat back forward. Turns out before 75, they didn't fold.Makes me more motivated to replace it with something else. Gonna keep it bench, but I think I'll look for something from the 90s.
They are 235/75r15. Based on how much the speedo is off I'm guessing factory was the 225/75. I'm looking to go to 31s if I can find a deal on some wheels I like. 5x5 bolt pattern isn't all that common except for some Jeeps and a lot of those wheels don't look right on a C10. But I want to do 31s to fill out the fender openings.What size tires?
That will tell you why it accelerates nicely.
I bet it is 235/75/15 or even 225/75/15
