Don't call it broflo dude! You'll screw up the search feature!Needs BroFlo
0411 LS ecm swap > BrofloNeeds BroFlo
If I don’t call it that, the hosers installing it won’t know what it is!Don't call it broflo dude! You'll screw up the search feature!![]()
Well by all means carry on sir!If I don’t call it that, the hosers installing it won’t know what it is!
So I hear that mentioned here and there.0411 LS ecm swap > Broflo
What did it run you?Picked up a 99 L29 last week from Tilden with a 140k on it removed from a fleet truck. It needs a fan, sensor and the harness to the transmission was cut. Otherwise it appears to be in good shape and Tilden told me ran well.
Now I need to figure out what direction I want to go with it.
Honestly I'm not even sure lol I was just stirring the broflo pot.So I hear that mentioned here and there.
Is it compatible with minimal work?
And what is the benefit?
I guess I will wait for more feedback on this but I am trying to get an l29 in my suburban and I know the stock ecm doesn't have much support so if it's beneficial and relatively easy I will try itHonestly I'm not even sure lol I was just stirring the broflo pot.
I do believe it will require repining the harness and I'm assuming more tuning capabilities along with a faster PCM. My knowledge of this is very limited but the 0411 ecm is the go to for gen3's as it is the fastest.
i just stopped in to say hi since you called my name i all .
Boy, good thing his name isn’t Carl...
Sooo, do you prefer hoser or Francis?If I don’t call it that, the hosers installing it won’t know what it is!
