Kind of my thoughts as well.
Martin
Martin
Why waste money on an auto setup especially the cost of a gear vendors or 4L80E when you'll just pull it and put in a manual. Do it once do it right
Now if we can just figure out if I buy a 71 chevelle wagon and use a tko 5 speed and gear it to run 1700-1800 on the highway can I make 550hp and get mid 20s for mpg?
going to sell me everything I need?Kind of my thoughts as well.
Martin
Oh and folkenheath, I like airflow and HP, it makes me feel all fuzzy and warm inside.
(That means try it and make a build thread about it) Ah, I wish it was just that easy. I simply don't have anything what-so-ever to do the swap at this time. Plus the trans swap (if I ever go that route) is what I consider phase three or four. Phase 3-4 is at least two winters out. I may never do the swap, I don't know. It just a long term goal/plan, as I said before.
Right now phase one is the engine swap and I am only focused on that. Along with the proper adjustments for my intended power level. Since I didn't receive any real input on this other then the obvious, do it once. I'll just stay with my original plan of tossing a t400 in it and calling it a day.
@folkenheath
Terry has driver seat on the fat block.
I didn't know he did all Ron's machine work. Email me if you want to talk more.
A 496 build with @folkenheath helping out. This feels very familiar. Looks like you had better luck finding a block than I have. Want to see how this turns out.
Yes, Heath has been a bad influence on me. Actually he told me to see if you wanted to part with your heads. I saw your engine for sale today. Pretty sure I am going with brodix or dart heads at this point though. I switched my machine shop to the same guy he uses. Turns out I lucked out with the core as I have owned it for 13 or so years and never cared to see what I had.
@Greg Ducato is going to set me up with a 400. It will be good enough for now.If you are staying auto just go 400. Not like it will make mpg worth worrying about. Big blocks make tq so you could run a 3.55 and it still will never hook.
A 80 would be nice I guess if it was a mild build like this but then with it being so mild I would be going to a manual to get back some excitement.
Stop being a pussy. No crusing rpm really hurts engines....
And weren't you just talking about spinning 1200 - 1800 RPM and now its 4000?
This. I don't want any breakdowns until I get a fully built rear end and that won't be this year.I did have a super t10 before but the constant 12 bolt ring and pinion breakage tied to the need for a $1000 adjustable clutch forced me to a th400.
