I think you should likely stick with the 24x setup since you are trying to plug into the tuned port intake stuff. I believe the IAC, MAP, TPS, etc will be the same connector, but I am not 100% sure. Worst case you may need to swap sensors or connectors to plug it in, not a showstopper. You definitely don't have the LS3 style MAP sensor so stick with the older LS harness. Does the tuned port have knock sensors? I don't think it does, you might just leave those unplugged then, but if it does do your homework, the holley can work with them, its just a matter of connectors. But you don't really need them for a tuned port NA engine.
Also, the Holley ECU is extremely versatile, its self learning with a handheld simpleness, yet you have guys with the same ECU winning drag week and running in the 5s or 6s in the quarter. Crazy versatility if you change your mind down the road and want to do anything in between.
Yes, I figured there's going to be details with the sensors that will need worked out. The plug for the iac will need changed and the tps can be easily swapped as well. I didn't know if it would use a MAF or MAP for the LS harness, but I will happily switch to either. The stock '86 MAF sucks with it's power and burn-off relays. My Accel 24# injectors use the old style Bosch connector, so those will need swapped as well. The knock sensors are the big question for me. The TPI setup just has one, and it's a single wire. The threads are npt, as it screws into right block drain. The LS style sensors are metric, non-taper IIRC.
When it's all said and done, I'm sure it will be spendy. But worth it.
