1977 Chevy C10 shortbed resurection/restomod/ratrod
Average User Rating:
5/5,
  1. kennyw
    kennyw N9PHW Premium Member
    Jun 9, 2002
    13,947
    870
    Stevens Pass Highway, WA
    Build(s):
    10
    Lowes had those for $4 each when I was looking for fittings. They just didn't carry a 3/8 x 5/16 that I wanted.
  2. diesel4me
    Jul 24, 2003
    24,263
    5,738
    Massachussetts
    The Lowe's a 1/4 mile from my house used to have one of the largest selections of brass plumbing fittings,but they keep reducing inventory--anything that isn't a hot seller doesn't get re-ordered--also they don't carry any 5/16" compression unions that I like to use on transmission cooler lines--the person running the plumbing section says 5/16" is "automotive" and isn't used in household plumbing,so they dont carry anything in 5/16" like copper tubing and other fittings..
    Home Depot has two stores ,both are about 6 miles away though,so I go there only if I have too..they may have more fittings than Lowe's..
    Lowe's now carries some weird type of compression fittings that don't use two normal looking ferrules too,only ones in 3/8" and 1/2" and 5/8" for copper pipes is all they have now for the typical ones..
    There are at least half a dozen well stocked old fashioned hardware stores in the next town over,but they are hit & miss as to whether you'll find what you need at any of them,and I have wasted an afternoon trotting from one to the other trying to find fittings,or enough metric nuts & bolts to assemble something..and their prices are butt rape..
    It ticks me off having to drive around all day just to get $10 worth of hardware..only 2 stores have a wide selection of metric bolts and enough of them to let you finish the job..
    I buy nuts & bolts at Tractor Supply by the pound,but they do not have much for metrics in stock,never the right length or pitch thread I need,or enough of them anyways..it's 9 miles to the nearest TS store..
    I buy up every bucket of fittings and bolts,nuts,etc at the flea market I come across..most of the time my garage has more hardware than some stores do..but I have hardly anything metric..
  3. mrk5
    mrk5 The Sticker Guy Moderator GMOTM Winner Author
    Apr 20, 2004
    17,426
    7,563
    Northern Colorado
    Build(s):
    I may be interested. I have to see what I can find for the bumper.
  4. kennyw
    Jun 9, 2002
    13,947
    870
    Build(s):
    10
    The only thing the aftermarket set is missing is the sheetmetal piece to fill the gap between the bumper and the bed. But they have the correct holes to mount it.
  5. mrk5
    Apr 20, 2004
    17,426
    7,563
    Northern Colorado
    Build(s):
    I've made that piece before. Luckily I have lots of drop pieces of aluminum sheet.
  6. Justin V
    Justin V I should've stayed up there Premium Member GMOTM Winner
    Apr 17, 2016
    4,840
    6,526
    Colorado
    Build(s):
    I have a 6 port selector valve that i don't need anymore. Feed and return lines...
    Feed are 3/8", returns are 1/4". Single wire.
    kennyw likes this.
  7. kennyw
    Jun 9, 2002
    13,947
    870
    Build(s):
    10
    PM me what you want for it, I can cap returns.
  8. kennyw
    Jun 9, 2002
    13,947
    870
    Build(s):
    10
    Let me know if you want the brackets. They just went on the shelf until I found a need for them.
    mrk5 likes this.
  9. kennyw
    Jun 9, 2002
    13,947
    870
    Build(s):
    10
    Even with new sending units in new tanks, I have the bouncing fuel gauge issue. Tonight I pulled the grounds, cleaned the frame mounting points, and reinstalled with new star washers.
    The problem still persists... it even moves when I turn on the headlights. I'm going to swap in a spare gauge cluster this weekend and see if there is a change.
    GWeakland620 likes this.
  10. mrk5
    Apr 20, 2004
    17,426
    7,563
    Northern Colorado
    Build(s):
    Maybe it's some of the other grounds; battery to frame and cab to frame?
  11. kennyw
    Jun 9, 2002
    13,947
    870
    Build(s):
    10
    That is another possibility that I will be chasing down as well. I do know there is an issue with the printed circuit where I cannot get the right turn signal bulb to work so I will be pulling the gauge cluster anyway to fix that. I have a known good cluster from the 3/4 ton 1977 GMC that was turned into a trailer.
  12. GWeakland620
    GWeakland620 THE CK5 Crayon Eater Premium Member GMOTM Winner
    Sep 15, 2010
    13,660
    11,900
    Toe-peek-ugh, KS
    Build(s):
    4
    I like this build.
  13. kennyw
    Jun 9, 2002
    13,947
    870
    Build(s):
    10
    The anti-build...
  14. kennyw
    Jun 9, 2002
    13,947
    870
    Build(s):
    10
    Thursday, my old boss at work asked if I wanted a motor from his boat, 1997 Vortec with 300 hours but the block cracked because water didn't get fully drained over the winter.
    Since I drove the truck into work, I wasn't going to say no... now to find another block.
  15. beags86
    beags86 Eastbound and Down Premium Member
    Jan 18, 2011
    10,153
    12,411
    Northern Illinois
    Build(s):
    3
    wasted wages and kennyw like this.
  16. kennyw
    Jun 9, 2002
    13,947
    870
    Build(s):
    10
    Today I picked up an older fiberglass canopy that matches the truck perfectly.
  17. kennyw
    Jun 9, 2002
    13,947
    870
    Build(s):
    10
    The wife caught me smiling driving this one today, guess is hard not to smile when they are running well.
  18. kennyw
    Jun 9, 2002
    13,947
    870
    Build(s):
    10
    I'm wondering if the loss of power going up hills could be the egr... I have an aluminum intake laying around. I think I'll grab some gaskets tomorrow and get it installed.
    I also got the trim reinstalled on the driver's door panel. Tomorrow I will replace the wing window and rival the panel.
  19. kennyw
    Jun 9, 2002
    13,947
    870
    Build(s):
    10
    Tuesday I worked from home and had a little extra time to pull the intake manifold and valve covers. I also plan to replace the engine wiring harness since this one was spliced at some point.
    Tonight I had a little more time after work and started cleaning up the aluminium valve covers and intake manifold I bought who knows how long ago.
    Tomorrow night I should be able to make some progress on reassembly.
    82355, Truckman4life and GWeakland620 like this.
  20. wasted wages
    wasted wages 3/4 ton status Premium Member
    Dec 3, 2003
    9,756
    612
    Dallas Texas
    Ole' motor looks fairly clean on the inside.. :D
    I don't know about you, but I ditch the end seals of the intake gasket set and use a good thick bead of black silicone...put some on the intake, and about a 1/4 - 3/8 thick bead on the block...I also spray the paper gaskets with high tack or copper coat on both sides before setting them into place.....line up all the bolt holes and let it set for about 5 minutes and set the intake straight down and bolt 'er up ! YMMV...
    hope it goes smooth for ya' and takes care of the issue...motors always just seem to run better with a freshing up of intake gaskets for some reason... maybe it's just me... :whistle:
    kennyw likes this.
