Xtremegmc80
anyone got the napa part# for rear brake line from the caliper to hardline. and the banjo bolt part number?? thanks in advance..
lots of pics to post tomorrow! im hopin to get this thing ready for the next run soon!
and i promise a smokey burn out with hummer tires when its all good!
Craig Artzner said:I like the new (older) headlamp bezels and grille you installed. Looks awesome!
Xtremegmc80 said:got the elect prob solved.. heres a night pic.![]()
the wire for the battery cable, theres postive- to the starter, negative- to the motor and the negative ground. the smaller wire- to the body for ground. i cutted the body ground, i gotta be more careful for next timejonrpick said:What was it?
Xtremegmc80 said:the wire for the battery cable, theres postive- to the starter, negative- to the motor and the negative ground. the smaller wire- to the body for ground. i cutted the body ground, i gotta be more careful for next time![]()
Craig Artzner said:Ever notice how electrical problems more often than not boil down to a bad ground? I always mis-diagnose at first and then BAM! it was a bad ground.![]()
jonrpick said:With me it's always loose, intermittent connections. Trying to track it down always involves wiggling wires until something happens.![]()
so i been doin bunch of stuff, checking oil, new plugs, bleed the brake sys very good. try to align the front the best i can, checking tc oil, axle oil. just the usual stuff, wires, makin sure nothing is missing. now i gotta make the rear n front bumper out of c channel steel and fab it up with my dad at his garage. i gotta drill one hole in the shackle so i can put the other 2 bolt in for the tow hitch, anyone know how much the original J tow hitch point worth? on ebay? its currently on my truck i want to take it off. thanks. so what u all think so far???nah i drove it up there straight, to rake up the driveway, and clean up all the mess from the truck, then drove it back in reverse.. at least i know the rearend works!Craig Artzner said:What happened? Did it roll down the driveway or what?
