When the pump was replaced last week the converter was warrantied. I think with my luck the converter is bad. I might drain the pan and add 5 quarts I have laying around.
I would just to be safe.
You also might want to switch which sock you put on first in morning. You've had a run lately, something needs change besides that oil
I just dont have a lot of time, in the next few days Im redoing the patio on my parents house. Tomorrow my brother and I are meeting with the house painter to go over with what he can and can't do.
I just got done with a 60 hour work week, and worked at night for 9 on the house and even re organized my own garage.
I'm tired...
I'm tired...
It's just a sock Ben!
Oh I know it will, found a few new leaks on the truck. Water pump is leaking from the steel hose bib, and my rear pinion seal on the AAM axle.
Also in the works is a sise job on a 73c10 engine swap.
