Sounds like a torque converter shutter
I'm leaning towards this but will check out the most I can before I pull it. The converter is under warranty though.
Shudder will be felt typically going into lock up, do you have the signal wire run right for lockup? If I recall you need to use a late model brake light switch, or do like I did the last time I needed to and accomplish the same thing with a relay. I want to say ecu needs to see ground with brakes applied
Vacuum leak wouldn't care if it was in gear or not
I'm so glad I set the 4 link to fit in a garage. I feel a sense of accomplishment having it in the garage on 35's
You probably don't wanna hear this, but i would change the trans oil.Rotated it and still the same crap, guess ill warranty the converter. It rotates freely off the flex plate.
If pump cooties didn't get cleared of the converter from last time, they're in pan now.
Unfortunately when i ran automatics, I became very diligent about going through converters whenever I heard a trans issue, for reasons like this
