B
Bent77
Guest
The answer is 6011...
You forgot to carry the 3
I don't know if I'm doing this right but . . .
Tensile of a grade 8 bolt is at least 120,000 lbs/in squared.
X4 =480,000 lbs/in squared
Shear is 60% = 288,000 lbs/in squared
3/8 bolts = 108,000 lbs.
I still think you are good. But I've had a couple of Modelo's so . . .
I'm sure it's fine but another bolt for good measure won't hurt.
If it is simple fix I'll do it, if it requires more I'll probably put it off.
Couldn't do that also but bolting sounds much better.Weld it on where it sits.
One weld each side on the front and rear. Done
Pretty sure Babs declined that already. 3 bolts per side is good.No @bent72 answer is 75/25+.035:230V
Dang it... Welding is neatPretty sure Babs declined that already. 3 bolts per side is good.
Rained that much?I'm terrible at math so I won't get into that conversation.
Good thing I closed the garage and went inside. My back yard has a lake.
It's our storm season, some parts the highways flooded last week.Rained that much?
I never really pictured that area getting much rain?It's our storm season, some parts the highways flooded last week.
