No unfortunately that was it, only one thing dumb I did and the truck went up just like it went down.
The factory used fusible links in the charge wire.Alternator goes straight to the battery, would like some protection if the alternator goes nuts. I like the way it was done from the factory in 82, cleaner setup.
No, the alternator puts out more amperage than that, correct?60 amp fuse coming from the battery to the firewall junction block. Is that enough to wire the alternator through to charge the battery?
Yes I want to run it like the factory system. That 60 amp fuse feeds the fuse block in the cab.The factory used fusible links in the charge wire.
That was a idea I was looking at, my brain and ocd keeps going everywhere and how much is to much or not enough? I think the alternator is a 120amp but could be a 140 I don't remember.I am fairly certain that you will need more than a 60 amp fuse for the cab. This is why the factory used another fusible link to send power to the fuse block. I believe that more modern stuff moved the fuse block under the hood to get the power sorted into the separate circuits and fused sooner.
You would just have to put in a fuse, most likely a manual reset circuit breaker that will open if the power cable gets a direct short. I would consider a 100 amp breaker to feed the fuse block. Then be very diligent about protecting the power cable and clamping it in safe places.
I dunno. hate to put a higher one in there and not have it blowI am fairly certain that you will need more than a 60 amp fuse for the cab. This is why the factory used another fusible link to send power to the fuse block. I believe that more modern stuff moved the fuse block under the hood to get the power sorted into the separate circuits and fused sooner.
I look at it as you are only trying to have it open if that wire/cable gets shorted to ground. The rest of the fuses protect the individual circuits.I dunno. hate to put a higher one in there and not have it blow
Does this make more sense?Ok so I thought about it and this makes more sense. Just run the battery to the starter, main fuse block power from the starter to the 60amp fuse to the junction to the fuse block. Then the alternator to the starter then up near the battery do a 5 amp higher breaker then the alternator output.
I agree with this. The fuse can be over sized. In my mind it's there in case of an accident and the cable gets damaged between the battery and the fuse block or whatever it's connected to.I look at it as you are only trying to have it open if that wire/cable gets shorted to ground. The rest of the fuses protect the individual circuits.
Agree 100%Overthinking something that doesn't need to be done, is where this has gone. But being worried about your alternator putting out to much power and rebuilding your electrical system to fix your worries is a waste of worry.
