But but, your bump stops don’t line up with your pads!
It is flat, but it has 3 holes in it. That plate is moving rearwards during compression and your bump nylon could slide over those holes no?Limit straps I need to buy they strike the spring plate which is perfectly flat
Solid, planted and much softer more control. The front isn’t taking up the abuse as much anymore.What do you mean? Just more solid and planted?
Because you didn’t think of it until now haha. I would also add a crossmember of some kind between your bumpstops so your frame doesn’t want to start twisting after repeated hits.It does look nice. Why didn't you leave the brake line T up at top of diff, won't it interfere with removing the gusset and diff cover there ?
