- Joined
- Mar 3, 2000
- Posts
- 9,160
- Reaction score
- 7,189
That is for dropping off rocks, the spring catches before the body does and lessens the impact.
Nope, once the traction bar is complete the rear end wont jump when the trans shifts.His new screen name will be, Babagoboing.
And the 81-82 bumpers just became cool in a new way....
It flat out works, I took the springs apart and bumped and dropped it so it had zero binding. I just did a burnout testing the drive shaft spacer and they spun to the 3rd gear just foot braking it with zero wheel hopAnd the 81-82 bumpers just became cool in a new way....
I'm curious how that traction bar works for you. It puts the leaf spring in tension under load like a cal-trac. Although those utilize solid front spring eye bushings which kind of hurt articulation. So I'm curious how effective it is without the solid bushing. The pivoting link extends the IC, so yours should be a little more AS, which has its pros and cons.
I hope it works awesome for you, nice work!
So... where's our burnout vid?
I’m pretty sure this was days after installing Greg’s transmission.![]()
Zero, and I have even ran the pan dry it fluid twice. I recently spoke to Greg about sending it back to him. Once I get my 85 done I’m going to cut the filter open and see what it looks like. If it shows some bad stuff it’s going back for a refresh and stronger parts…How many transmissions have you replaced since then?![]()
Wow, he didn't even call you out and yet you responded within 5 minutes.How many transmissions have you replaced since then?![]()
Spec’ing out my transmission build with @Greg Ducato and waiting patiently for my turn on his operating / assembly table!Wow, he didn't even call you out and yet you responded within 5 minutes.
Where have you been man?
I thought you were going manual transmission.Spec’ing out my transmission build with @Greg Ducato and waiting patiently for my turn on his operating / assembly table!
-G
