The radiator is a half inch away from the top of the core support. @Wes Harden @6872xtc
you mean fan shroud ?
Put a strip foam to reduce the air flow through the gapWell I put it all back together and it’s less then 3/8 away. I think it should be fine.
Thanks for the link that seems like the ticket.you could use some edge trim clipped on the shroud. won't gouge the core https://www.amazon.com/15Ft-Black-Edge-Trim-Automotive/dp/B0894W7V2Z/ref=sr_1_2?crid=20ZYTQNNTGI5X&keywords=u+shaped+weather+stripping&qid=1696309240&sprefix=u+shaped+weather+stripping,aps,125&sr=8-2&th=1
Brother.It's officially done, you won't see it on anymore rock trails unless it's the easy stuff.
I say this then next year it’s back in the rocks… This year I specifically said I wasn’t going to bring the truck, even told my close friends that I’m probably not going to Moab for this reason.Brother.
David
It’s hard but I want to preserve the truck as long as possible. I have already wheeled it way harder then I thought I ever would.Every year I say I'm going to back off the snow runs because it's hard on the truck....
Also ever year:
I hear ya. I swore up and down I would never do a 1 ton swap on mine because I never planned to wheel it hard enough to need it. welp, here I am. :PIt’s hard but I want to preserve the truck as long as possible. I have already wheeled it way harder then I thought I ever would.
That’s partially why I didn’t put a 60 in, I also had it laying around. I’m pretty sure it still has factory u joints in the shafts.I hear ya. I swore up and down I would never do a 1 ton swap on mine because I never planned to wheel it hard enough to need it. welp, here I am. :P
Yes every time, I have a theory behind it…yeah but is leaking from the same place ?
4l60e where the trans bolts onto the tcase.4l60 or ? Which side trans or t case
