That is supposed to be an o ring there, I wouldn't use rtv with an o ring. Maybe a skim coat of flange sealant, being careful not get any on oring
I think I’m not explaining it right. That o ring is in and not leaking it’s the tcase side as in between the adapter and tcase.
Paper gasket and rtv. Mine didn’t leak there with that combo.
I use a very thin amount on both sides of the gasket with both mating surfaces clean of garbage.
I went as far as using a wire wheel on a grinder to lacquer thinner to clean it…
I’ll be going about 35 mins to my brothers, will check it then check it again about mid point where we always stop. Then will check it again at the lake. On the way back it will be the same stops.
Might be doing some night driving as well so I cut part of the light harness and connected it to my msd solid state relay and they actually work now lol
I don't believe that the input seal on the T case would make it leak from the adapter housing. It would overfill the T-case, yes.
What's your thoughts on this?
I wiped down the breather tube and moved the truck 20 feet, over night it’s leaking out and the fill plug is leaking to. I think Both are leaking, on poison spider hill you could watch it pump out.
