Yeah it is. My problem is I have way too much other shit that also has to go in the garage.
Just wait, I have a ton of crap too just hasn’t made its way over. I just found out it won’t fit forward has to be backed up.
When I put the truck together I dragged it out of my sisters garage with the front end on a cherry picker. Lifted until the cab was an inch below the garage door and took measurements for the coil overs. If my memory is correct it has 6 inches of up travel and 8 inches of droop.
Sense I sold my 85 C10 that was the mistress, it’s time to start back up on this.
I couldn’t fine a decent sport bumper for the 85 so I took it off the 82, found this for $100 yesterday and snatched it up.
Also have a new 90mm throttle body coming to get rid of the Chinese 102mm TB that whistles at idle.
Spot welds popped?
That happened to a set of aftermarket fenders I had a while back. The inner and outer skin basically completely separated before I found some clean original ones.
Spot welds popped?
The piece that runs below the grill cracked at the corner and it looks like the spot welds for the bolts broke. Honestly, not really sure haven't looked at it.
