Of course, it will be a few weeks as when I pull it out I’ll swap the cam and bolt on the supercharger.Nice. Don’t forget pics before you install it!
No, he wants you to take a picture of it when it shows up. Don’t give us this “ We’re waiting stuff.”Of course, it will be a few weeks as when I pull it out I’ll swap the cam and bolt on the supercharger.
Thats a nice part. When mine dies ill have to upgrade to this
It wasn’t that bad priced either and cheaper than the alternatives that are glued together. This is fully welded so I feel much more confident in it.Thats a nice part. When mine dies ill have to upgrade to this
I have put a straight edge on it and confirmed it is straight.You sure the mating surfaces are flat?
That’s what’s on it.Did you try the RightStuff?
lol I know, I just don’t want to fix it then drain it a week later. This week it’s going to a show on Friday and then the cam swap happens.The water pump is easy. Ask me how I know lol
I have tried anaerobic on it as well, same results. No they are not blind they have holes. I also studded the tcase so it just has nuts on the outside.It's eating through Right Stuff? Wow
Maybe try one of those anaerobic sealants certain manufacturers use for oil pans and the like. I think there's a Mopar or a Honda brand one most guys swear by. Perhaps someone knows what I'm talking about?
Also it's not leaking from the bolt threads is it? I forget are the holes blind on the tcase?
It looks like the case wasn't cleaned enough before applying the right stuff so it didn't stick well.Also it says in the product features it’s resistant to atf…
The Right Stuff Black 1-Min Gasket Maker, 5 OZ | Permatex®
Replace cut gaskets in one minute. Install parts immediately. OEM-approved. Oil and coolant resistant.www.permatex.com
I used a wire brush attachment on my angle grinder to clean it and wiped it down with brake cleaner after.It looks like the case wasn't cleaned enough before applying the right stuff so it didn't stick well.
I don't believe ATF affects it
YesIf it was coming from the trans wouldn’t every auto that’s mated to a 241 do it?
