for sure use lock nuts. 10mm might fit the holes tighter with out drilling. Can even go JIC washer head fine thread 10mm
Do you feel any vibrations when you're driving? It's hard to figure the amt of vibrations or movement you've got to be getting to cause all of the bolt problems you've come up with.
Wonder if hanging some cameras under once you have this all back together may give you some views on things.
The entire truck rattles with the cam it has, it would shake the mirrors.
