Mine has a noticeable lean and really exposes the kings.
Tomorrow is my only day off this week, next weekend I get Saturday and Sunday. I think I will wait for the seal.
Hmm. I still don't believe. Not saying it's not possible, but I just don't think you get 300hp to the ground, never put out a puff of smoke, drive it for a couple months with everything basically fine and still end up with a has in the oil issue. The only possibility I can really see is if one of your injectors is leaking while the truck is off and filling one of the cylinders with fuel that then leaks past the Rings. Other than that, if you actually had one of the bad scenarios which allow fuel into the oil, it would show itself in other ways more than just fuel in the oil.
it has glitter in the oil, verified off the dipstick and its thin, pulled all the plugs and number 2 was wet.
new injector on the way and a oil change. I hope im not bonned on this...
Rip 6.0 you took me to Moab and wheeled all weekend. You were able to smoke the 35's and make me feel like a little kid.
It's louder as rpm rises and sounds like metal on metal on a bearing. The engine is full of metal, drained the oil.
Most likely, but what's the crank and cam going to look like? Going to weigh my options and see what happens.
