Turns out he didn't go through it, so I traded a crappy trans for a crap trans, but this one hits the gears just manually.....
Why? Haha
So when you put it in drive it won't move at all? But when you put it into manual 1 it goes?
Once you get up to speed, can you put it in drive and it works?
Sounds like a burnt clutch pack to me, when you put it in manual 1 it applies a second clutch pack that allows the truck to move.
Man Ben I wish you were closer a basic rebuilt kit isn't that much. I'm not totally confident myself but I have a buddy who has just kept an eye on stuff to make sure I get it right.
Correct 1 and 2 move the truck.
Wait.... You had your so called buddy " rebuild" your trans and he just switched it out for a used one? So you did all the work to put it in and he just told you so?
Pretty sure at this juncture he should be required to pull it back out of the truck. I could be good natured about the trans, but your time and the misconception. I would be pissed.
I knew it was used but was told he was going to take a look before it went in. Well he didn't and the trans doesn't work right.
That ain't something a buddy does, especially since I'm assuming this buddy should know the vortex of suck you've been through with this truck already.
