I'll reuse them, just won't go ham and cheese on them. The axle we took apart to get the open carrier out just took a screw driver.
His adjustors are just beat up they in no way shape or form need replaced. Just need cleaned up some and the biggest reason is so no metal might make its way to the ring and pinion.
Most people the first time they do em mess em up pretty good. I have seen way worse than what Ben did
The biggest problem I've seen is when they put them back in the wrong sides and crank the bearing caps down.His adjustors are just beat up they in no way shape or form need replaced. Just need cleaned up some and the biggest reason is so no metal might make its way to the ring and pinion.
I'm making a bunch of mental notes for when it's my turn.
This is why I posted my mistake . This thread is a learning curve for me and I hope others can learn off it.
Ive always just found a good Phillips screw driver or punch that fits nicely, and made sure it was long enough to go all the way through and catch a hole on the back side as well. Paired with a hammer.
I know Eric said he made a tool for doing it, and I have an idea of what he did, but not really positive.
This doesn't really show much, but here's what the tool is "supposed" to look like, according to the CUCV manual. It has a couple pegs that go into the holes. I can't remember if there's an actual picture of it (didn't find it in my super-brief search), but I was thinking that the pegs didn't go all the way through to the backside.
Id bet they don't go all the way through either. Instead of grabbing on hole on both sides of the adjuster it grabs two on the easily accessible side. Wouldn't be hard to duplicate
Mine went all the way through. Correctly sized Phillips worked perfect for mine.
It's my blazer bash list toYeah, that's a pretty big punch list for 3 weeks.
