bp71k5
3/4 ton status
Here is a dumb question, should the fuse go before the solenoid or in-between the fuse block and solenoid.
Also not really sure I'm comprehending how they take a battery hot and it switches over. I guess If I could see a diagram that would help.
You really don't need a fuse to protect the fuse block, but if you want to protect the solenoid, the fuse needs to be between it and the battery.
