Don't see any wear in the tube or anything. The shock didn't leak at all, was only down I think 30-70 psi of pressure. I don't remember if I set it at 200 or where king says at 150.
You need to figure out where it came from. Unless Fox built them with the crap in it. Which I doubt, but it might have beer 30 on a Friday.
Fox? hahah
I'll inspect it a little further when I have more time. I didn't see any crazy amounts of wear or pitting on anything. I did notice some amount on the wear band,assuming that's what caused it.
7th page back and she is still being neglected... work is freaking nuts, I haven't even looked at the truck in over a month.
Mostly looking at the shock hoop placement. No need to do any work for pics or anything, I appreciate it.
Mine are not the ones ord supplied, they capture the top and side of the frame. They are welded then 3/16 plate against it to create a double welded joint. I can pull the cross brace off by hand and put it back in over the engine.
