Oh I see, the cooler is -8 the lines are -6. They do make a -8 to -6 reducer.
I'm trying to run the lines from the bottom of the core support up to the cooler. If you follow the line you can see the dark shadow of how it's ran. I didn't explain myself very well before.
This would be much easier if I mounted the cooler lines facing down.
But something in the back of my head is telling me that's not a good thing because it can drain back? I can't remember why I mounted the lines facing to the side.
This is the cooler I have.
https://derale.com/product-footer/f...unt2013-10-28-09-53-271226240719/15900-detail
It traps air in the top of the cooler. You need to have the ports face up or at least sideways. Or you have to Pressure bleed it to make sure you get all the air out.
That’s what I was always taught about cooler mounting.
Thanks, I just forgot the reason why I did it like this.
So I had the exhaust wired up with bailing wire, it fell down and cracked at a weld. Had the ex girlfriends Dad cut it off with a sawzall...
Decided it was time to pull the shocks off to service them and it's a good thing I did, one of the shafts is bent....
Yes 35's fit with no lift.
How did that happen. Only time I bent one is when a panhard bolt broke.
Pretty sure my heavy right foot had something to do with it hitting 3 foot whoops and no bumps.
I think it's because I drilled the ord brackets out and the pan hard mount is hitting the cups.
It's Ben do you really need to ask ? :D:doah:
What's that supposed to mean? :D
:thinking:
