Should be prepping the firewall filler pieces this weekend and hopefully install.
@ktmoutfront what was the process we did on the firewall? I forget if we wet sanded the primer to 2000 grit and what we started at.
I have found ignorance is bliss. Never worried or even thought to much about trans cooler. Add 1 make sure is not leaking.
Until I put a temp sensor on my suburban. Now I am thinking back on all those high horse power engines I added and never considered the trans cooling.
I have a huge Derale cooler combo, I need to install, is going to be remote location. Is to big to go infront.
Sorry to add an item to BB thrash list.
Learn by messing up, just read the first few pages of this thread...
Probably not but more is always better? I'm even debating about adding another cooler...
Not necessarily. It's possible to impede airflow. As far as I know, only testing can tell you what happens. Try it with and without, or check airflow rate with a anemometer.
