Rear Disc Brake Conversion:
I had every intention of fixing the drums brakes on the 14-bolt, but I just happened to jump on Ruff Stuffs website and saw they we having a 15% off sale on their brake kits. It was an easy decision from there, as I have been running one of their kits on my K10 since 2018 with zero issues. To compliment the new parts, I also ordered up ORD's brake line kit for disc brake conversions, as well as their improved design 14-bolt hub seals.
Taking it all apart was easy. I blasted out the wheel studs with a brass drift and mini-sledge.
You can see here the hubs seals were definitely ready to be swapped:
New two piece seals:
Fresh rotors installed onto back of hubs with the same studs:
Axle ready for the brackets:
Caliper brackets installed (I had painted them a while ago):
Hub and rotor, along with new caliper installed:
Ruff Stuff uses brand new calipers, that are universal side to side. Yes, they have two holes for the banjo bolt, and two bleeders. They send them loaded with pads and hardware. When I ordered the kit, I asked if I should paint the calipers, and they said that they are coated with a heat treating, so there is no need to paint them, unless I wanted to. I kinda like the silver.
The brake lines are soft, and ORD's kit comes with P-Clamps and bolts to secure it the axle. I tacked two of the bolts on to the tube for the P-Clamps. I also ran the soft lines under the springs; on my K10 they go up and over the springs. I am not so sure I like it this way, but we will see.
Also, check out the difference between the way the drums used to stick out and how the discs are tucked in nicely:
After bleeding, I took it for a test drive and the brakes feel awesome! It slows down nice and straight, with a firm pedal, and I don't think I will need an adjustable proportioning valve. I am very happy with the results.
