1985 D30 M1008 BUILD 52s/37s
Hopefully you don't need to adjust your Drag link and Steering link much you didn't leave much adjustment in them.....
Have not adjusted them alt all. They are sitting on there
Got the rear disc brakes all buttoned up. Need to figure out the rest of lines and proportioning valve. That includes deleting the load leveler if need be? Does anyone ever use the proportioning valve on
load lever?
Wow so I did them completely wrong. Great
I'm about 100% sure mine never came w/ instructions when I installed mine....
If mine did I have yet to find them. Il have to look later. The dog may have ripped them up if anything lol
If you're running it offset like I did, these old photos may help.
Ya I get it now. I put them upside down. What would I do without ck5!!!
Ok when I asked earlier if the 52s were supposed to be this flat. I was referring to what I had been looking at here on the passenger side. This is not right. The drivers side is better. Yes the passenger side is also 2" lower. I think this spring may be shot. This it full weight on wheels
