Quick update. I got my 6 degree shims for the front springs. Picked up some new U bolts as well. Have not had a chance to install them yet. Hopefully next week. Once I get the shims in and the extended brake lines in I will be able to cycle the front suspension and see how much fender I will have to remove.
I did talk to Tom Woods about driveshafts. They agreed one of their superflex U joints would help get a few more degrees out of the front shaft. They also said I should be able to grind the yoke on the axle side to accommodate a few degrees more.
I did grind a bit on the yoke and was able to get rid of the majority of the binding (I was in a pinch and needed my lift bay to do a brake line repair). I was able to move it around now without the fear of ripping the front driveshaft out. I think with the 6 degree shims and the superflex joint I might be ok.
As soon as I get a chance to cycle the rear suspension and measure for a driveshaft I was given the ok to order one. Planning on a 1350 CV with the thicker .120 wall tubing. It will be nice to have rear wheel drive again.
