Front axle is completely rebuilt. The kit was from Ord just like everything else on the truck.What's the specs on the ram? There are bolts in the rear of the knuckle to adjust turning radius but I would be careful because it can break ujoints and shafts, or the knuckle if it pushes to far.
Have you checked your kingpin bushings, shackle bushings and any other parts in the front for the cause of your dw
I have a Dodge D60 in mine with ORD spec 8.75" PSC cylinder. Looks like you have the same bolts as steering stops that i did.I finally got around to installing my hydro assist in hopes of curing my death wobble. While cycling the steering its seems the ram has more travel than the steering stops allow. Can i adjust them for more angle without breaking joints?
The axle is a dodge d60 with yukon axles and spicer jointsView attachment 500806View attachment 500807
Thank you Stephen. It appears I should take a closer look at my steering setup as it sits right now as well.Here's some stuff I wrote up a while back on steering stops:
Steering stop setup:
Reid knuckles require grinding the stops to the right length, if you mess up and go too far:
1: cut them down farther, drill and tap the knuckle and run a bolt for a steering stop, or
2: weld a pad on the axle housing for the knuckle stop to hit or add some weld to the knuckle stop. The knuckles are cast iron but will take a weld good enough to act as a steering stop.
Stock knuckles use a bolt and jam nut style steering stop that can be replaced with a bolt using a solid spacer or combination of spacers. ("Spacers" can mean washers) It can also be replaced with a high grade bolt and jam nut like the factory system but even high grade bolts tend to bend so a solid spacer is a more reliable way to go.
Max steer angle will be limited by something. Generally, this is the binding point of the axle U joints but it could be tire clearance to a spring or link, or even something like the axle shaft hitting the steering knuckle. This is the point at which the steering stops need to engage. Keep in mind that aftermarket axleshafts can often be ground/polished to increase their available steer angle.
At this point, the steering cylinder needs to be timed to the steering stops so the cylinder doesn’t push on the stops. This can stress the knuckles and cause them to break. If the cylinder travel is more than the tierod will travel, the cylinder can be limited internally with a spacer. A cut down shaft clamp or a simple washer can make a decent external limiting spacer too.
ORD steering systems are designed for a tight turning radius and some allowance for compliance in leaf spring suspensions. Ideally the draglink throw will exactly match the steering stop placement and the cylinder throw but with leaf springs the axle’s side to side motion makes it virtually impossible to achieve. A little more throw on the draglink than the rest of the system is better than too little since you don’t want the box to be the limiting factor in your steering angle.
Some care in driving is very helpful in keeping a steering system alive. Holding the steering wheel against the steering stops or against an obstacle that stops the steering system will put the pump in bypass mode and create a lot of heat and angry steering fluid is very hard on pumps. If it won’t steer, don’t force it.
Kind of a repeat of some stuff from above but mostly same ideas. If you have our 1.75 x 8.75 cylinder, you will need to mess with the stops and you'll be glad you did.
How are your ride heights working out now? Adding the D60 and some rear weight probably helped level it some.
Thank you for all the info. Ride height is perfect and the ride is amazing. I will mess with the stops next. I think I have to look into a new pump also. Its a psc stock replacement style but the steering is harder than before the ram unless its revved up.Here's some stuff I wrote up a while back on steering stops:
Thank you. It gets us where we like to campRad burb man
Looking at your camping and scouting pics. Makes me miss Nor Cal…Thank you. It gets us where we like to camp
