Boring post. Rear window bottom channel rusted out so I had to take it all apart. Replaced the channel the window sits in, both left and right channels, inner and out window seals and greased everything. Found a new aftermarket switch to fix the window control for the tailgate from the outside. Doesn’t look OEM but it was cheap and it works. It’s hard to find the oem switch and they’re very expensive. Also got new window seals for doors. Man that stuff is expensive too.
