1989 blazer electrical plug question
bmrudolph
Newbie
North Carolina
My son and I have been doing a rebuild on a 1989 full size Blazer. We took the dash apart 2 years ago (obviously didn't take enough pictures :) )and now putting things back together. We are replacing the instrument cluster with a Dakota Digital cluster. There are 2 wire plugs that we can't figure out where they go. Pictures are attached. Anyone have any suggestions?
Is it for the power locks??? If you have power locks there is a relay or solenoid if I remember correctly above the ac heater control under dash
It was the power door locks. The relay on this model is not behind the air controller. It is in the firewall next to where the steering column goes thru. Thank you for the help
