Look at the mains like suggested. What shape is on the prechamber cup just for fun?
. You know I am old, everything in my mind is $30 from Napa, starters, alternators....Well like you guys I have subscribed to the crazy.
@80' 427
Napa here said 95 bucks. Rock auto has em cheaper by a long ways.
You looked at the shape stamped on the head not the opening shape right? Almost all of those heads are cracked between the valves. You can have them fixed with the valve guide trick or just run them. The 93s won't be diamonds unless they have been replaced. Not a huge deal I just wondered for when you get it together.
If they're dry (i.e.: not into the water jacket) run 'em, and keep your engine cool (below 210°F...max...ever). I run a 195° stat and keep my eye on a good aftermarket temp gauge.So if the heads are cracked I have to run them. I'm struggling to get where I am with it.
If it runs fine should l start looking for heads? Or ignore the cracks?
What's the eventuality of cracked heads?
I can't see any issue with the mains but it seems to really look you have to pull the caps. Which I guess is no biggie.
I might have to anyway I have a new rear main gasket in my rebuild kit. So I'm gonna replace that.
Anyway up to this point I think there might be one crack in the heads. But it was very hard to see.
The precombustion chambers are oval.
No biggie. I have a 93 6.5 sitting in the garage I could pull the heads and see if they have the diamonds. But is it really worth the trouble?
I just wondered what cups it has, I didn't suggest changing anything. Stop reading into my posts you buncha womens.
