I can stop by after work tomorrow if you do not figure it out before then.Man I screwed something up, now the Blazer won't start. Just cranks and cranks...
Tried starting it without that green wire connected. Was planning to use a voltmeter to apply ground to that wire with the engine running and video tape my temp gauge to see whether the needle moved at all. Anyhow when I cranked the key the Blazer fired up but the enginer starting was louder than usual and it died immediately. I reconnected the green wire shown and tried again, all it will do is crank but it won't actually start. One weird thing I want to mention is that I heard some noises coming from the back of the engine bay near the firewall on the passenger side. Then when I put my key into the ignition a short bit later the radio was making some seriously weird noises. This is with the ignition at the "OFF" position. I turned the key to the "ON" position and the radio came on like normal. But it was making some weird-ass feedback noises before then. Spooked me a little bit.
I checked some of my fuses, IGN / ECM / ECM B... they're all fine. Will try to get further tomorrow.
Any luck?Man I screwed something up, now the Blazer won't start. Just cranks and cranks...
Any luck?
Ron is a stud for sure and willing to help anybody. Glad he was able to help you.So tonight was pretty outstanding. @Capt Ron came over, found about 4 or 5 issues with my Blazer, fixed them, and left all in about an hour and a half or so. I was in awe.
Hopefully I get all this right, I wanted to write it all down so I remember this stuff. A lot of good lessons learned tonight.
Work ahead of me:
- Truck wasn't starting.
- Couldn't hear fuel pump come on but we were getting fuel at the injectors.
- Ron was in the engine bay when I cranked from the driver's seat, he saw a spark arcing near my exhaust manifold.
- We tried one more time to start it up and a fire started on my passenger side exhaust manifold. We were able to blow it out. The manifold was wet, presumably with gas (?)
- Pulled the nearest plug and it was dripping wet with gas. Engine was flooded.
- We disconnected the injectors and pushed out a bunch of the extra gas through the open spark plug hole.
- Ron found that one of the spark plug wires in that area was burned through because it had been rubbing on the exhaust manifold.
- Tried starting it again and the truck ran even with the injectors disconnected for probably 5-10 seconds. Just had been flooded with fuel.
- We pulled a second plug and it looked okay but Ron noticed a crack in the first plug. The spark coming from the plugs in that area was weak.
- We connected everything back up and the truck ran fine but was idling high.
- Ron found a vacuum leak in one of the hoses back near the firewall. We cut out the old brittle stuff and replaced it with some spare hose I had in my tool chest.
- Still was idling slightly high, Ron took a look at the distributor and found that the cap was real loose. The clamp needs to get tightened down.
I am still not sure what caused my engine to flood in the first place, perhaps it was a weaker than normal spark due to the plugs and/or distributor cap and/or the damaged wire. Perhaps it wasn't burning up all the fuel coming in from the injectors and it eventually flooded.
- New plugs / wires / distributor cap / rotor.
- Need to tighten the distributor clamp.
- Replacement hose for the patch we made near the firewall.
Tremendous thanks to Ron, can't say it enough. I think once I get the spark plug / wire / distributor job done my Blazer will feel brand new. Almost certain that this will cure my rough idle blues I've been dealing with.
As far as it getting flooded to start with, loose cap causing no spark but the injectors are firing is a quick way to do it.
But the takeaway I get from this is, don't overlook the basics. Ron's old school and that's second nature for him. But even on a simple efi system it's common to over think the problem and reach for the bigger/more expensive part. Check the basics always. You'd be surprised how often we fix stuff in the shop where others have gone overboard and we find something simple and small as the cause.
Sounds like you got a good weekend wrench session coming.
I don't know about that.I finished replacing cap, rotor, plugs, and wires last night. The Blazer fired up but had no power when I took it for a test drive.
At first I immediately thought I got the firing order wrong. I took care to follow the order printed on the intake and started at the 5 o'clock position on the distributor cap.
I have just one question for anyone out there:
1. My dumb ass put dielectric grease into both ends of the spark plug wires. I was one of those guys who thought it helped with electrical connections... turns out it doesn't conduct electricity at all according to what I read last night. I am guessing that having dielectric grease in the distributor ends of the spark plug wires is my main issue. Do you guys think I can get that crap cleaned out with q-tips and brake clean?
Thanks as always.
