It used to be a TBI350 thing I read here on CK5 to advance the base timing to 5° BTDC instead of 0°. Back in the day when the TBI swap was what the LS swap is today.
Start it again and warm it up. Those codes could mean nothing at this point. Old truck, cold, etc. 10-15 seconds isn't enough to rely on.Went out to the garage tonight to try and start up all of my junk. I realized that I haven't done a good job of starting stuff up regularly and that I need to do a better job of that.
Status report:
When the Blazer was running I noticed the check engine light was on and it stayed lit. So, I checked the codes and now have some new clues for my issues.
- Sportster
- Started with some convincing, ran fine once warm.
- K30
- Wouldn't start. Cranked many times with no go. I think I tired out my starter. Never had an issue starting the truck while warm so I'll try again tomorrow. That big block must be real cold.
- Blazer
- Started after a couple of tries on the key. Harder to start than normal. Barely stayed running, lights were flickering and it was vibrating bad. I shut it off after maybe 10-15 seconds.
CODE 42 ELECTRONIC SPARK TIMING
CODE 44 LEAN EXHAUST
Never seen those codes before on my Blazer. Gonna do some research on the site and see if I can figure out what's going on. If it is running lean then perhaps that explains the low power and the vibration at idle?
Timing is still advanced 5 degrees.
When it's really cold like I know it is there now it's normal to run rough like that for a little bit, you need to let it run till it warms up and smooth out.Went out to the garage tonight to try and start up all of my junk. I realized that I haven't done a good job of starting stuff up regularly and that I need to do a better job of that.
Status report:
- Sportster
- K30
- Blazer
Sometimes carbs can really be hard to start cold. Sometimes the fuel bowls are just dry and need to be refilled.
I've said it in lots of places on CK5, but if you're running a carb these days I would highly recommend buying alcohol free gas.
If not able to get ethenol free, use an additive. I use Lucas, the only ethenol free is in 5 gal cans and $50+ .
That sounded horrible. Did it have oil pressure? What is the temperature and what weight oil is in there?
