It has been a long time since I've updated the thread...
I picked up this bad boy from @ZooMad75 about three weeks ago now (sorry dude). It took me a while to really dig into the Blazer again, but I've gotten back at it over the last week or so.
The first thing I decided to do was to clean up the passenger side bracket where I had used a file to grind out some metal for the new ORD brake lines. I bought some bigger files from Harbor Freight and I took my time with it and tried to make the surface mostly smooth and an easy fit. It came out looking like this (which is a lot better than it used to be, I promise):
I then reattached everything on the passenger side and shifted focus to the driver's side. The driver's side was still the old line and whatnot - I had not broken the old stuff free yet.
I started off with some more PB Blaster, a couple of hits with the hammer, and then got on it with the flare nut wrench. It did not break free and once again I thought I was going to end up rounding off the nut. So, I decided to just commit... and I cut the factory flexible brake hose. This allowed me to get the closed end of a wrench around the "outer" nut and the flare nut wrench around the "inner" nut. I did the "clock trick" that @Wes Harden and @mrk5 mentioned earlier in the thread and it finally broke free. Thanks for the tips guys - I yelled out loud in triumph when it broke loose.
I used the new round file to grind out metal on the driver's side bracket, and I'm proud of how it came out. I don't have a pic unfortunately but it's quite a bit cleaner than the passenger side. Tonight, I went out and installed the new ORD brake line on the driver's side.
After I got everything connected, I went and took a look at the rear brake line. Doing so made me notice that I had two nuts "left over" in the kit, which was a huge
moment for me. If anyone is curious, the nuts that I'm talking about are circled in red here. I did all of that work grinding metal out of the factory bracket so that I could reuse the factory horse shoe clip to keep the flexible brake hose in place. It looks like these nuts can be used instead of the horse shoe clip which would mean that I didn't have to do any of that grinding with the files. So it goes I guess. I decided to "do it right" and disconnect everything again... I then installed those nuts along with the horse shoe clips.
I sprayed the rear brake line stuff with PB Blaster and called it a night. I am really hopeful that it will be easier in the rear than it was in the front. The only big concern other than things being seized is that my skid plate for my gas tank is sorta in the way. I would love to do this rear brake line job without taking that thing off... but I suppose we'll see.
The plan now is to install the ORD brake hose in the rear and then bleed the whole truck with Zoo's extractor pump. I'll start with the wheel furthest from the master cylinder and work my way through all four. Fingers are crossed that it works out and that I can get to driving this thing again. I realized today that it has been down for about 6 weeks!
Thanks again for everyone's help through the front brake line saga.
moment for me. If anyone is curious, the nuts that I'm talking about are circled in red here. I did all of that work grinding metal out of the factory bracket so that I could reuse the factory horse shoe clip to keep the flexible brake hose in place. It looks like these nuts can be used instead of the horse shoe clip which would mean that I didn't have to do any of that grinding with the files. So it goes I guess. I decided to "do it right" and disconnect everything again... I then installed those nuts along with the horse shoe clips.I sprayed the rear brake line stuff with PB Blaster and called it a night. I am really hopeful that it will be easier in the rear than it was in the front. The only big concern other than things being seized is that my skid plate for my gas tank is sorta in the way. I would love to do this rear brake line job without taking that thing off... but I suppose we'll see.
