I was bummed I couldn’t stay all day to help. The three of us can usually get things done fairly quick. We don’t get much time in the shop together, its usually trail repairs.
Engine stumble most likely is ignition. EGR shouldn't fix it. Plugs, wires, distributor cap, rotor, ignition moduel, 99% guarentee one of those parts will fix your issue
Ignition moduel do weird things. Order one and change it out. Next if that dosnt work then id go for the Ignition pick up coil, in that case just replace the whole distributor which will come with a Ignition moduel. Catch 22 situation.Thanks man! I've replaced all of those except the ignition module at this point. Probably worth it to take a look at mine.
That's sort of right, but you don't really care about the angle of the driveshaft. It's the angles of the T-case and the pinion that need to match. As you shim the pinion up, the angle of the driveshaft changes, which moves both of the numbers you posted. As stated, you can measure it with the square and a plumb bob (which is basically what the magnetic angle finder is) or a smartphone app, as most phones have accelerometers built in.
- Driveshaft is angled 2 degrees up from the pinion side u-joint.
- Driveshaft is angled 8 degrees down from the t-case side u-joint.
I guess in my head I was thinking that since everything is fixed in place, I can infer the angles of the pinion and t-case by using the driveshaft as a static reference point.
Either way I'll start by ...taking Zoomad up on his offer of equipment and advice to help me do this accurately while learning something....
You can use the driveshaft as reference no problem, as long as you do the math correctly, any reference worksI guess in my head I was thinking that since everything is fixed in place, I can infer the angles of the pinion and t-case by using the driveshaft as a static reference point.
Either way I'll start by trying to rig up a plum bob with a shoelace and a nut and then will measure the t-case and pinion outputs against the vertical plum bob line.
Ha! I love hanging out with @ZooMad75 regardless of whether there is work to do... so being honest this will probably happen also.Fixed it ?
I can come over at some point this weekend. Just let me know what works for you.Ha! I love hanging out with @ZooMad75 regardless of whether there is work to do... so being honest this will probably happen also.
