I like the hub caps but it’s not too late for some 14” Barts. Just sayin….
Yep, but I put it on the correct side where it belongs.@Bent77 has a high pinion ford in his k20
I never noticed that, so you relocated the tubes to make it passenger side?Yep, but I put it on the correct side where it belongs.
The entire driveshaft is above the leaf spring
I don't believe it is.If OBYUAN uses an O.G. ‘79 high-pinion Ford D60 it will damn near be a bolt in as is as far as leaf springs are concerned - I assume that’s what he is doin ?
Where is this mysterious beast?Yep, but I put it on the correct side where it belongs.
It's his blue 77 long bed k20 in his avatarWhere is this mysterious beast?
I guess he switched to his Camaro but it used to be his avatar for a while.It's his blue 77 long bed k20 in his avatar
I believe its a early '90s ford dana 60 he cut and welded to be for a chevy.If OBYUAN uses an O.G. ‘79 high-pinion Ford D60 it will damn near be a bolt in as is as far as leaf springs are concerned - I assume that’s what he is doin ?
Are you talking about @obijuank5 ?I believe its a early '90s ford dana 60 he cut and welded to be for a chevy.
