scpaul
I'm doing some touch up on a '90 Jimmy that has one of the GM 2 color paint jobs. It's silver (Dupli-color BGM0508, the dominant color) and dark gray (Dupli-color BGM0536, the secondary color). I did some edges of the doors where they had rubbed things like brick walls, they wern't bent. The dark gray was a perfect match. The fiberglass top was the same dark gray. It was badly faded on top and some on the sides. The dark gray that's a perfect match on the edge of the metal door is no where near the same color when sprayed on the fiberglass. I lightly sanded the fiberglass before I started spraying. The gelcoat was in good shape just faded. I have put 3 complete coats on the top thinking that maybe the lighter faded areas were causing the difference in color. It didn't change at all. I used a small area and put 3 more coats on it. The color still didn't change. It's somewhat close to a battleship gray with a little more gloss not the dark gray that the color was supposed to be. Remember that the different 2 colors came out of the same can. The same wrong color has now come out of a total of 6 cans.
I have sent Dupli-Color a pic and basically I was told that since the color was right on the metal that it's basically my problem about it being a different on the fiberglass.
I guess that I'm going to sand it, prime it, which it shouldn't have needed since I was putting the supposedly same color on. Someone suggested that there was a chemical reaction between the fiberglass and the paint. The first 3 coats had been on for about 3 days, so I thought that iit should have sealed the fiberglass so the paint couldn't touch it because of the 3 coats that were on it. I sprayed a small area with 3 more coats over the next 2 days. That small area is the same color as the other part of the fiberglass that only has 3 coats.
If there's anyone that can explain what's going on to me I would really appreciate it. With what has happened, I don't know if priming it would help since it had the original 3 coats on it and didn't they didn't make any difference at all.
I have a pic in my sent e-mails, but don't know how to e-mail it to this forum.
Any HELP before I go to a shrink would be greatly appreciated, Paul
