scpaul
I looked through the factory catalogs and it's the primer for the OEM Acrylic Lacquer paint which is the type that their product is.
If I use the resin and thin it so that it is absorbed better, what do I have to do for the resin to take the primer or is the sanding to remove the hairs enough. Is there a second part that I need to add to the resin? What do I use to thin the resin and what amounts of each. Would a second thinned resin coat help or should I do it a second time only if some of the fiberglass hairs are still there? Where can I get the resin, parts house, Lowes, Walmart, etc. and is there a brand that I do or don't want?
85, I know that anything's possible, but if there was any difference you couldn't tell it because of the different finish if nothing else and it came from the factory with the right paint codes on the window sticker. There's always the possibility that I'm a little color blind, my dad was with certain blues and greens and I'm not trying to be smart, my dad really was partially color blind.
I really do appreciate it, Paul
