Having fuel pressure readings only in a shop environment isn't as useful as real-world driving data.
It does not read fuel pressure, but I am looking into fuel pressure/EGT's/Boost sensors that will be compatible so that I can monitor those.Does your truck have a fuel pressure sensor? If so you could just hook your new SuperCoolMegaGaugeReplacerThingy to it.
Well either way, the truck had a desired timing of 10* and the actual timing was 25*, that's a pretty clear sign that things are on their way out. Plus with 176k and it most likely being the original pump, it's time to get those maint. items done that will cost me an engine in the near future.Having fuel pressure readings only in a shop environment isn't as useful as real-world driving data.
So when I replace the pump, I plan on replacing the dampener along with a 1 piece crank pulley as well. Are the other things that I need to do at the same time? Like timing, or any important seals?
Water pump is good PM, and I’m a big fan of timing gears. You’ll have it down just about far enough to put them in. That, or a fresh chain.
David
This. Throw a new timing set in there, along with the crank seal & gaskets that entails. If you're pulling the IP, water pump and damper, it's just a few extra bolts to get it all done.
Water pump was another thought of mine. I'm just going to plan on spending more like $1,500-$1,800 total with added maint. items. I just want to be good for another 178K miles.Water pump is good PM, and I’m a big fan of timing gears. You’ll have it down just about far enough to put them in. That, or a fresh chain.
David
All engine bolts are metric, so 10, 13, 15, 17, and 18 mm will remove 98% of bolts on a 6.x engine.
If you're going to run the one piece crank pulley I strongly recommend getting a fluidampner to go with it. The solid pulley transmits more harmonics then a standard dampner go handle.
It’s either going with factory replacement stuff, or billet pully with a fluid dampener.If you're going to run the one piece crank pulley I strongly recommend getting a fluidampner to go with it. The solid pulley transmits more harmonics then a standard dampner go handle.
I like timing gears also, then you know your timing will never change unless you do it.
It's pretty straight forward job to do. Definitely doable over a weekend. All engine bolts are metric, so 10, 13, 15, 17, and 18 mm will remove 98% of bolts on a 6.x engine.
All of the V-belt trucks ran one-piece crank pulleys. Is it really a problem?
I was told the fancy pulley was to help decrease the impact from suddenly stopping the long serpentine belt, so you don't hammer your tensioner. Not an internal issue at all.![]()
Snuck outside early this morning to make some progress on the springs. Bushings swapped and on its own weight. Need to bolt up shocks and spring plates after church, but shouldn’t take more than 20-30 minutes.
New spring pack is 1-1/4 inch taller than the old pack, but the new springs are only 1” lift instead of 2” lift springs. With the weight of the truck, I think I may have kept the ride height the same.
